Quote:
direct quote from that site...
8. Run the best unleaded fuel you can. If the compression ratio of the engine is up near 11.0:1, it will love 100-octane unleaded. Remember, the higher the octane, the slower the fuel burns.
I am not sure if Octane has any thing to do with flame speed which is primerely a function of hydrocarbone content in the fuel.
"Octane Number: The octane number of a gasoline has little to do with how fast it burns or how much
power the engine will make. Octane number is the resistance to detonation. If the octane number is high
enough to prevent detonation, there is no need to use a higher octane gasoline since the engine will not make
any additional power. Octane number is not related to flame (burn) speed either. Variations in octane quality
are independent of flame speed. There are some high octane gasolines in the marketplace with fast flame
speeds and some with slow flame speeds. It depends on how they are put together. At Rockett Brand
TM, we like
fast flame speeds because we know that a properly tuned engine will make more power on this type of gasoline
than one that has a slower flame speed.
Power: The ultimate goal in the racing gasoline business is to convert chemical energy from the gasoline
hydrocarbons into mechanical energy or horsepower. The most efficient way to convert the gasoline into horsepower
is to have the correct air-fuel ratio and the correct spark timing. A mixture that is too rich or too lean will
not make maximum horsepower. The same is true of spark timing: too much or too little will compromise
engine output.
Summary: As indicated above, flame speed and octane number both impact the amount of power that an
engine will develope, but they are independent of each other. To get maximum power from an engine, one must
have a gasoline with adequate flame speed (faster is always better), and adequate octane quality to support the
combustion process. Tied in with the optimized air-fuel ratio and the spark timing, we have a winner."
web page
