Wire run
Main charger wire needs to be a 4 conductor 6 gauge wire.
This can be run to a NEMA 14-50 socket, a NEMA 14-30 socket, or hardwired.
If using a NEMA socket, remember, the 14-50 is rated at 50 amps, but you can under size the breaker for safety. (20, 25 or 40 amp, rather than 50)
The NEMA 14-30 is rated for 30 amps, so a 20, 25, or 30 amp breaker can be used.
Hardwire-match it to the recommended breaker
if you have one more open space in the fusebox, I would also run a 10 gauge 3 conductor wire for a 20 amp, 120 volt, dedicated circuit. I would use a plain 20 amp, 120 volt breaker, but run it to a Weather Resistant 20 amp GFCI.
This is for charging with the on-board charger, just in case.
