What does viscosity index really mean?
Northern California (Vacaville)
Okay,
I am told that the higher the Viscosity Index number is, the better the oil is at withstanding change due to temperature.
So, I understand this to mean that the oil doesn't crap out when it gets hot and can still pour when cold. If this wrong, please feel free to educate me.
Here is the confusion: many oils I looked at have much better VI numbers for their 5w30 than for their 10w30 or 20w-50. Example: Mobil 1 5w30 has a VI number of 167, with 10w30 of 147. Castrol GTX has numbers which consistently lower the higher the vicsocity is, so that 5w30 is much better than 20-50 (160 to 128).
Shouldn't the thicker oils have better numbers?
Bob W.
Your definition of VI sounds right.
All of the 5w30s should have had higher VI than the 10w30s. Viscosity Index is calculated by taking kinematic viscosity at 2 temps; one at 100C, the other at 40C. The less change in viscosity, the higher the VI. 30 weights will have roughly the same viscosity at 100C. A 5w30 will have much lower viscosity at 40C than a 10w30--hence the higher VI.
Thicker basestocks generally have better VIs than thinner ones as long as you're comparing apples to apples.
I can send you a kinematic viscosity vs temp chart where you can plot the lines out and see the relationship for yourself if you want. PM me with your email address
[ September 07, 2004, 07:00 PM: Message edited by: Jay ]
Now I am really confused: if a 5w30 has a greater change in viscosity, shouldn't it have a lower number?
Bob W.
Bob W.
Okay, I get it now: the VI measures the change between the original weight and the viscosity at 40c, right? This is opposed to the change between 40C and 100C, yes?
Since 5w30 has a lower 40C viscosity, it is closer to the orignal viscosity where they measure the 5w, in the 5w30, at least I think....
Bob W.
Bob W.
Yea the 5w30 will have a slightly higher VI.. Its really a meanlingless number any more with multi vis oils. It can be found by calculation, with a graph or with a chart. But-again - who cares
Bob, exactly right. Look at a spec sheet for various 30-weights and look at their viscosities at 40 and 100C. You'll see that the 0w has lower viscosity at 40C than 5w, and 5w lower than 10w, etc.
A high VI is a good quality for any oil to have--especially motorcycle fork or shock oil. Those have VIs in the high 300s and low 400s.
