A used oil analysis from Blackstone cost $35 bucks, about the same as an oil change using a PF-48 and Supertech 5w30 from Walmart. My 2016 2500HD has a 6.0 vortec and usually the OLM tells me to change the oil at around 6500 miles.
If I want to extend my drain interval, I'd assume I'd go with a more expensive oil and filter, and then at 6500 miles or so send off a sample to be tested. But if I used Supertech and the PF-48, I could just change the oil for that price. So I guess I don't see really what I stand to gain - changing the oil isn't much more work than pulling a sample. Once I put on work clothes, pull the truck into the garage, and get my tools out, I feel like I may as well change the oil?
If I had to guess, maybe the benefits start to accrue after you do the first used oil analysis. Assuming I used a premium oil and filter and the first used oil analysis told me I could go another 6500 miles, then on the second OCI I don't bother to do a used oil analysis - I just drive 13k miles straight without ever crawling under the truck.
Is that the theory behind used oil analysis and extended drain intervals, that once you do the first used oil analysis you can safely extend the drain interval without doing another used oil analysis for a while (say 50k miles)?
