I had a GN400 years ago but it was a Suzuki Motorcycle.
FWIW-
https://www.northerntool.com/products/wen-rv-ready-4000w-open-frame-inverter-generator-surge-watts-4000-rated-watts-3500-voltage-120-model-gn400i-5808965
Other retailers are advertising for more than WEN direct sales.
Miscommunication or just sloppy WEN management?
So your switch just ties the neutral to the frame / ground pin? I presume all the outlets already have the neutral tied together so you just had to grab one point?Adding a switch to switch from floating to bonded
Testing to see how well it picks up a 1200w load
Take aways from this if you are going to convert to tri fuel your best bet is to go with motor snorkel or be prepared to trim air box.
