I have a private well and my well tank became waterlogged. It is the type with the bladder in it to keep the water apart from the air charge. I decided to save about $300 and put in a new bladder rather than just buying a new tank. Sears was the cheapest place on line for the bladder for my 82 gallon tank. About $115 delivered.
Glad I did as it was only about an extra hours worth of work to change out the bladder compared to changing out the tank. The key is to fold the new bladder as tight as possible with two people and lube it with alcohol gel get it go in the hole in the bottom of the tank. My son and I pulled the old bladder out with vise grips.
The shock was when I looked inside the old bladder. It was coated in a horrible multi colored slime. It was different thickness around the inside of the bladder and looked more like it belonged in a septic tank rather than my well tank.
We never see any discolored water or particles in the water though. My wife and I talk often how we must have some of the best tasting well water on the planet. We never get sick.
Do any of you have any suggestions or methods that you use for your own well that would keep this stuff from forming? I could put a chlorinator on the well but I would rather not drink chlorinated water.
Thanks!
Thanks!
