I once had the front wheel come off a MkII Jag I was driving.Coming down a long steep hill,everytime I braked a horrible noise came from the front wheel...finally near the bottom the wheel came off.As I was fighting to bring the 3 wheel car to a halt,I watched the wire wheel go across the road,launch over a flax bush and disappear.When I went to look for the wheel,behind the flax bush was a car with the wheel embedded in the drivers door.
It had wire wheels with knock off hubs - the hub and wheel are splined.A common problem was the splines corroded,and then stripped....this normally happened on the rear wheels as there was more load.On the right front,the hub locks under brakes,and the knock off unwinds....and off goes the wheel too.
