weird looking oil, less than 1000 miles
Metroplex,
I would certainly try to lean out the carb as much as possible, since you're running a cool
thermostat.
You also might want to open up the carb and make sure the float level is where it should be, since a high float level would make it run rich.
And then change oil and filters at maybe 500 miles until the rich mixture situation is
brought under control.
I clamped down the fuel evap hose so the rich condition should be gone.
The oil turned black almost as soon as this hose was loose, so we'll see.
