Very, very, good post ^^^^^^^↑^^^^^
I would believe It's not just particles I would be concerned about...
The inhalation of aerosolized droplets.... That are less than 5 microns in size. Or even down to 400 nanometers in size.
A very well made and properly fitted n95 mask is highly efficient down to 300 nanometers. With a beta ratio over 75 at that size droplet or particle.
Thanks! Yes the aerosolized droplets are an issue. The droplets will have solvent and possibly carry those emulsified particles as well which will solidify. I should have been clearer when I talked about aerosolization. Any kind of respiratory protection is a good thing, even N95, as far as stopping larger droplets and particles. However solvents will still get through as they evaporate, even on the mask surface itself.
For organic vapors from solvents and chemicals like acids there is a rule of "if you can smell it then your protection isn't working", and really only chem carts with activated carbon will block those vapors. Even if you don't have a chem cart, it is still better to wear N95 or a P100 particulate filter than nothing, because at least you won't be coughing up the emulsified solids later. Without a mask at all I'm sure many have experienced spraying spray paint and then having that color mucus come out of you later that day, at least N95 will prevent that even if it doesn't stop the solvent inhalation.
@oesman, first of all thank you very much for the great hard work you are doing at
Dmitry's Garage! The wax ratings are very useful.
I have a question. About 27 hours after I applied Turtle Wax Ice Seal N Shine, I drove the car on a cold (~ 57 °F), humid night. As soon as I got out of the garage, condensation occurred on the paint. It was really a lot of condensation, and the paint looked very cloudy and uneven, especially on horizontal panels. I was looking at other cars and no other car had as much condensation as mine. In fact there was one very well-taken-care-of silver SUV, probably detailed, that was parked out there in the parking lot, and there was no condensation on it whatsoever! How can this be? Do some waxes attract moisture more than others? Is this because it was only a day after the wax was applied? Did I do something wrong? The car certainly doesn't look good when it is so cloudy. Here are some pictures. Note that I also waxed the black grill around the Toyota emblem. I rubbed my finger on the mirror to show the condensation. The next day the paint looked normal. Perhaps it looked a little lighter than without the wax.
You're welcome, and thank you for checking it out!
I would wonder if the other cars had simply been outside for a while? My garage is climate controlled and some days when I pull outside the right conditions of temperatures and humidity hit dew point. Even without HVAC garages will have a different humidity and temperature to outside air. As I pull out my vehicle starts to get condensation on it and my windows fog up. I have to sit there for a bit with the air blasting because I have zero visibility.
Typically its a problem in the middle of winter and middle of summer. So my guess is the condensation is simply due to you pulling out of the garage and hitting the right conditions for dew point at that moment. The other cars never met those conditions or already passed them having been outside a while. I'm sure when you got to where you were going you didn't have condensation anymore, right?
As for the uneven condensation it is likely related to the wax. Wax will cause water to bead more and it's possible you had high spots in the way you leveled the wax. Sometimes this is due to missing spots or not fully wiping up spots or using too much product. I have seen this with some wax applications, especially products that don't easily self level. This isn't typically a big deal unless you can tell in normal conditions.
Thanks for acknowledging my points/observations. It's not always easy to even take constructive criticism, especially when you put a good deal of effort into something like you have here.
I always welcome constructive criticism, because it can result in interesting discussions and thoughts. Some have led me to change my methodologies. Any thought out replies are always good.
Thanks for putting this together. I'm always interested in durability, as some of my vehicles get washed often, and one sits outside 24/7. It helps a lot to have data.
No problem! My aim is to keep expanding this list and expanding my testing
This is a very instructive thread.
@Gokhan , I haven’t had the condensation issue on mine but I’ve noticed that pollen seems to attract to the body surface more more with the Griots 3 in 1 Ceramic. Just overnight after I washed and sprayed the car I go out to see the dusting. It seems to stick rather than blow off while driving. A quick wash takes care of things but I don’t recall this happening with other products.
This is a good observation, I've found some products seem to generate more static cling.
