N Neil Womack Joined Jun 9, 2002 Messages 718 Location Central Texas Aug 8, 2004 #1 I was wondering if anyone had an opinion about water pump lubricants? Saw a can next to the Prestone this morning and wondered about its benefit.
D Dan4510 Joined May 19, 2003 Messages 2,359 Location Texas Aug 8, 2004 #2 From what I understand, you only need that if you run water only for coolant. Anti-freeze has the proper additives for that. I could be wrong though. Dan
T theguru Joined May 3, 2003 Messages 988 Location Melb, Aus Aug 8, 2004 #3 In most cars the coolant is enough, however, some such as the GM 3.8 ltr V6 used here in the Holden Commodore has water pump lubricant tablets for adding to the mix.
