I have a 97 z28 camaro and i believe my water pump is leaking. I believe it is my water pump but not 100% sure. Its on the drivers side and coolant lines run to it and it doesnt appear like much else is going to it besides some electic cables and an accessory wheel i think.
I havent seen it leak in action but i keep finding little puddles every now and then underneath it. I could be wrong too because its leaked in different spots and im not sure its even coolant but looks like it. It seems that some liquid leaks into the wire looms and slowly moves around and drops in different spots.
How do i find out if its leaking and if it is, is there anything i can do to stop it without hurting my cooling efficiency or anything else.
My car runs at 170* and i keep checking the levels on everything and everything looks intact. I did a dexcool flush about 3000 miles ago.
