I'm starting to use my basement more; and it stays kinda cold in the winter. I put up some 1" thick foam insulation onto the cinderblocks; that raised the temp about a degree. I think the big problem is the breeze coming through a horizontal flue on the furnance. Ergo, I am thinking about making a removable wall around the furnace. [Due to space constraints I can't just make it into its own room.]
I'm guessing I need an air intake, preferably with a one-way flapper (ala dryer vent). Would a 4" hole be good enough? Or should I use two of those? It's not a big furnace, I don't know size off hand but it's a typical Beckett burner, heating a small house. The flue does have an fan in it, to ensure draft, so it does pull a good amount of air.
