have a poulan PL-25 weed trimmer. ways back after i got it the original carb (don't remember which make/model) [censored] out and rebuilding it didn't help. so i bought a whole new carb, a walbro wt-631 is what showed correct for that trimmer from whatever website. bolted it on and weed trimmer ran like a champ for past few years.
this year it's been slowly loosing power until it would only idle, if i gave it any throttle it would go blaahh and stall out. if i could get it to spin up managing the throttle there was no power and whenever cutting thick stuff the engine would stall right out.
so i bought a rebuild kit and cleaned the thing out, put all new gaskets, same problem.
undid everything including welch plug this time and soaked the body in a gallon of berrymans carb cleaner for 30 minutes. used 100 psi compressed air to really blow it out, then reassembled. engine will now run and have power but no where near it did when the carb was brand new. at full throttle you can still feel and hear it's lean, but at least it has enough power to cut. but it doesn't have that snap throttle response like it did when carb was new. I really don't feel like buying another new carb.
anybody know what i can do? the fuel lines are good, and the tank is clean and the stone thing in the tank with the fuel filter is bright white and completely clean. so i'm pretty sure it's not dirt clogging the carb, i'm guessing it's the @#$%'ing ethanol fuel varnishing up and clogging the carb over time.
if i do go a new carb again, anybody know how/where i can look up all the various models of walbro carbs? because this wt-631 does not have any adjustable jets so if i buy a new one i want adjustable high and low jets that i can remove when i eventually have to clean it.
