w126 1988 300sel Benz-NGK spark plugs
CA
I own a 1988 300sel (w126) Mercedes Benz and pretty much have settled on using NGK non resistor spark plugs.
Now the question is,
Do I use NGK BP5ES or NGK BP5EFS?
I read that one has the crush washer(BP5ES) and the other plug has no crush washer and is tapered for correct seating.
I also read that some just remove the crush washer and then such plug becomes a BP5EFS.
Do I have the correct information?
Is the correct gap .030 or .032 ?
Please advise
Isn't a TR5 a resistor plug? There is an "R" in the number
Yes, it is a resistor plug. What brand or part number is OE? Those old German cars used resistor spark plug wires so you def don't want to double resistor. lol
Yes- just saying that is what the parts look up calls for. What made you decide that you need a non resistor plug?
edit- I see above me lies the answer. What about replacing the wires with a modern equivalent?
NGK calls for wire set EUC041. Maybe replace the resistor wires so you can source readily available and correct for application plugs?
afaik-iirc OE fitment specifies only tapered seat plugs.
Family had W126 380, 420 and 560s a while back. Solid as a bank vault and ignored bad pavement like a destroyer crossing a sailboat's wake. Great cars!
