For anybody that cares (and those that don't), here are 3 pictures of the liter of VW power steering fluid that I picked up from my local VW dealer today. 1L = $18
Originally Posted By: simple_gifts
I thought you were selling that car.
Not enough interest from prospective buyers. Decided to keep for at least 2 more years. After doing the math, it made better sense to hang onto her for a while.
I'll use this new VW fluid to slowly replace the old fluid. I'll leave approx. 1/4L in the bottle for any future top-ups that may be required. I'm not planning any future maintenance to the PS system.
In the event I ever need to replace the PS pump, I'll probably purge the system & re-fill with Mobil 1 ATF, which is less than half the cost of the VW fluid.
If you think the fluid is old and intend to replace that with this VW expensive fluid, I think mixing will be a waste.
Its like draining and filling the transmission pan with Amsoil syn ATF when the half the old fluid in the converter is going to mix with the expensive syn ATF.
Purging the PS of old fluid is real simple.
1) Drain the reservior and plug the return line connected to the reservior and point the return line (smaller of the lines connected to reservior, its mostly a 3/8") to a empty gallon jug. Fill reservior with fresh PS fluid.
2) Raise the front of the vehicle and do steering locks meaning put ignition key in ACC and then crank it left and right. While doing this old fluid is manually pushed out while filling the reservior with fresh fluid.
3) Once 3/4 of fresh fluid has passed thro the system via the reservior, reconnect everything back. Fill the reservior to full and start engine and do steering locks left and right 5 times to purge air of the system. Top it off and you are done.
Note most cars have 1L capacity for PS systems (big behemonths like trucks etc may be more).
