Volvo 240 Power Steering Reservior
Sam_Julier
$50 Site Donor 2025
Staff member
Connecticut
The return line nipple broke off in my hand while removing the hose.
Glad it happened in my driveway and not on the Cross Bronx Expressway!
Working on a remote reservoir configuration. This would isolation the engine vibrations.
  • Like
Reactions: wlk
Volvo 240, '80s era? I'd put an OEM back on it. It's seen a lot of time and miles, right?
Sam, I think we've talked about this before, but Sue's and my first brand new car was a 1982 Volvo DL 2-door with 4-speed manual and overdrive. Without question one of the top 4 best cars of the 30 or so we've owned. Super reliable and rock solid.
Scott
If you were closer, I would just give you the entire pump assembly from my wife's 91. After one of the small lines on the rack got damaged, I patched it with a piece of fuel hose and never reinstalled the belt to the pump. 4 years later, it's still the exact same way, I found it really easy to steer even with the power steering not enabled.
Thank you. That is a kind thought.
I had a unit in my stash of 240 parts. It’s in the car with a new return hose. Return hose is an OE banjo, two high pressure clamps, OE hose. Mobil 1 ATF. Car is running perfectly.
Sam
Scott
Thanks Scott. Totally agree.
OE unit back in the car. Mobil 1 ATF. Running perfectly.
I love owning, driving and maintaining these cars.
