This is mainly in the context of miniature ball bearings.
I don't know where this goes, but this site seems to be one where it is more likely that people know what they're talking about. There doesn't seem to be a general lubrication subforum here, this section seems to be appropriate.
How is the appropriate oil viscosity determined for an application?
What are the consequences of using a lubricant that is too low or high in viscosity?
How is the appropriate lubricant fill determined?
For example, common lubricant fill for greased bearings is about 30% of free volume. Why 30%? Why not 5%, 10%, 20%?
The SKF lubrication selection app determined that a lubricant of about 10cst at operating temperature was appropriate for a miniature ball bearing.
Why 10cst? Why not 3 or 5cst? or 40cst?
The use of a higher viscosity lubricant increases the torque value (churn, heat, use energy). But what if you lower the lubricant fill (which seems to counteract what a high viscosity lubricant does) with a higher viscosity lubricant?
Higher lubricant fill with a lower viscosity lubricant VS a lower lubricant fill with a higher viscosity lubricant
Pros & Cons? In all or as many properties as possible (wear, lubricant life, torque, energy/heat... lubrication in general/detail)
The use of a lower lubricant viscosity vs oil plating with a higher viscosity lubricant?
As viscosity goes up, film strength goes up.
As RPMs go up, the lower lubricant viscosity required, why is this? Why are higher viscosity lubricants appropriate for slower moving (operating) bearings?
There's the factor of viscosity at start up.
Too much lubricant can mean churning and overheating.
Too little means poor lubrication in general..
Carrying away heat is also a reason to need plenty of oil, where there is an oil circulation system?
Would power steering fluid work well as a bearing lubricant or general lubricant? Why or why not (not just "it wasn't meant to be," in terms of its properties and composition)?
The description/features/properties on the package/label sound like it has the properties needed for a bearing lubricant.
Sometimes ATF is used in place of power steering fluid and vice versa.
And some seem to use ATF as a general lubricant.
How do I find out or what stores sell Mobil 1 Velocite No. 6 Spindle Oil?
What 10cst or lower oil @ 40C or lower would I be able to easily find/purchase that would work well ball bearings?
I think it would be a good idea to have EP additives for shock/impact loads..
What are the common EP additives (solid film lubricants?)
Graphite, Moly, Tungsten disulfide and...?
Is PTFE is an EP additive? Seems that Teflon has lower load carrying capacity.
