Do you want to extend your OCI past the OLM? If so, then yes. You generally do not want to run an oil past when it reads 1.0 on TBN; some people ascribe to not running it past 2.0. It is a measure of the acid-neutralizing properties of the oil, and below your comfort zone means the oil will start to allow acids to cause harm to the engine.
If you run by the OLM and/or stick to 5K OCIs, then save your money. TBN on almost any syn oil will make it 6k without blinking.
