BrendanC
$100 site donor 2024
E-core as seen in some of the RP filters would be even betterEndurance would be more compelling with holes like the rest of the Fram products.
for a filter that costs the same as a boss, why would you expect it to have a silicone O-ring and not the boss?The India holds it's own I think & for the cost/Claims I expect a red silicon Oring gasket on the Endurance.
Simply India is not a 20,000 mile rated filter. Cost being equal the Fram is expected to last a lot longer duration.for a filter that costs the same as a boss, why would you expect it to have a silicone O-ring and not the boss?
that has nothing to do with saying for the cost it should have a silicone O-ring. i’ve never seen or had a nitrile O-ring leak. i love the silicone o rings on the PG’s but i don’t think it’s necessary. silicone ADBV is far more important IMOSimply India is not a 20,000 mile rated filter. Cost being equal the Fram is expected to last a lot longer duration.
Cost depends solely on what one pays for either filter & that can vary. When PG's can put one on I think the higher tiered/higher cost filters should do as well. We have a separate set of expectations & you're happy.that has nothing to do with saying for the cost it should have a silicone O-ring. i’ve never seen or had a nitrile O-ring leak. i love the silicone o rings on the PG’s but i don’t think it’s necessary. silicone ADBV is far more important IMO
overseas manufacturing is also cheaper per unit. but it still really isn't warranted, just a want from all of us.Cost depends solely on what one pays for either filter & that can vary. When PG's can put one on I think the higher tiered/higher cost filters should do as well. We have a separate set of expectations & you're happy.
The Boss is rated at 20K miles and it doesn't have a silicone base gasket. Now that the long life PG built filters have a silicone base gasket, people seem to think all filters should have a silicone base gasket, or they aren't "high quality".Simply India is not a 20,000 mile rated filter. Cost being equal the Fram is expected to last a lot longer duration.
Haven't seen enough long 20k ODI's for it to really matter that much so in that sense it's not. However, I would feel more confident running an Endurance or any premium long drain oil filter, for 20k, if it also came with a silicon Oring.overseas manufacturing is also cheaper per unit. but it still really isn't warranted, just a want from all of us.
First, No one is claiming "aren't high quality" w/o silicon Oring but everything can be improved & some may be just fine with no progress forward. However, Boss should have it too period. Again, If PG can do it & keep costs down so can the premium brands that advertise double the mileage.The Boss is rated at 20K miles and it doesn't have a silicone base gasket. Now that the long life PG built filters have a silicone base gasket, people seem to think all filters should have a silicone base gasket, or they aren't "high quality".![]()
Appenently you forgot where PGs are made vs most of the Purolators. Last time I checked, the Boss was still made in the USA. Maybe if M+H moved production someplace else they could improve it without raising cost or even lowering the cost.First, No one is claiming "aren't high quality" w/o silicon Oring but everything can be improved & some may be just fine with no progress forward. However, Boss should have it too period. Again, If PG can do it & keep costs down so can the premium brands that advertise double the mileage.
Wrong, I know where these filters are made. Silicon Orings can be made in the USA & is not exclusive to foreign countries. You or I don't decide what that cost is for that improvement & could very well be made cheaper right here in the U.S. However, nothing is stopping them from sourcing silicon material from other countries. Which they may or may not do already on some material. "Made in the USA w/ Global Material"Appenently you forgot where PGs are made vs most of the Purolators. Last time I checked, the Boss was still made in the USA. Maybe if M+H moved production someplace else they could improve it without raising cost or even lowering the cost.
Maybe you should get on the board of directors at M+H if you think they can swing silicone base gaskets. Or stop buying them instead.Wrong, I know where these filters are made. Silicon Orings can be made in the USA & is not exclusive to foreign countries. You or I don't decide what that cost is for that improvement & could very well be made cheaper right here in the U.S. However, nothing is stopping them from sourcing silicon material from other countries. Which they may or may not do already on some material. "Made in the USA w/ Global Material"
Maybe you should get on the board of directors at M+H if you think they can swing silicone base gaskets. Or stop buying them instead.![]()
I will continue to buy American Made M+H SILICONE o-ringed filters.To add, a silicone base gasket is a nice touch like on the PG and similar filters which are rated to 10K miles, not 20K plus miles. But it's not really as important as a silicone ADBV for a long OCI rated filter, otherwise many other long use filters would be using one too. Maybe it helps the filter unscrew from the engine at filter change time. Some Purolator use to have the Teflon coated base gasket for that reason.
Are they really 100% silicone? I don't think so, as Purolator's website still says this below, which is what the have always been like I mentioned above. If they were actually silicone, they would say so on their website. It's treated with Teflon, but is it 100% silicone beneath that coating? Burn one some day and find out. What's puzzling is why don't they use that style of base gasket on the Boss which is rated for longer use?I will continue to buy American Made M+H SILICONE o-ringed filters.
Woops, You're correct. The Purolator One's I posted are PTFE treated Gasket.Are they really 100% silicone? I don't think so, as Purolator's website still says this below, which is what the have always been like I mentioned above. It's treated with Teflon, but is it 100% silicone beneath that coating? Burn one some day and find out. What's puzzling is why don't they use that style of base gasket on the Boss with is rated for longer use?
https://www.purolatornow.com/en/products/oil-filters/purolator-boss.html
It’s teflon over nitrile probably in the One, so allows less friction like a teflon coated frying pan. I don’t know what other base rubber it could be besides nitrile synthetic rubber. The Boss has ethylene acrylic something different than anyone else as you state. More expensive material.Woops, You're correct. The Purolator One's I posted are PTFE treated Gasket.
The Purolator Boss's state:
Just bing searched some comparisons & PTFE is good for High Heat but doesn't bond very well. Acrylic is good for "Dimensional Stability" (Keeps it's shape better?) And must be more important for the longer duration. No one wants a leaky gasket! LOL
- PuroSEAL Gasket™ made from ethylene acrylic for maximum leak protection and life expectancy
https://standardmachining.com/ptfe-teflon-vs-acrylic-pmma-properties-and-differences/#:~:text=PTFE is more resistant to heat and chemical,it won't warp or change shape over time.
