- Joined
- Nov 19, 2020
- Messages
- 403
Getting back into vintage stereo. Recently set up my 40 year old system of Hafler amp and preamp with Luxman turntable and Canton speakers. The system sounds as great as I remember with excellent soundstage. Despite the fact that I always took good care of my albums I found the surface noise disconcerting. I know vinyl will never be CD or streaming quiet, but I was looking for some improvement.
After some research I came upon Spin Clean. Uses microfiber brushes and rollers to wet clean records while spinning them manually. Despite looking clean prior to cleaning, I was amazed at how much junk was removed from the grooves. The solution is a mixture of distilled water and two capfuls of their proprietary solution which is supposed to encapsulate the dirt and allow it to sink to the bottom.
Pictures are of the device and an attempt to show the amount of crud removed from 20 records. Kind of hard to see, but the water was murky with lots of dark stuff on the bottom. The results were incredible. Quality of the music and surface noise improved by an estimated 90%. Not the most high tech, but very effective.
