Single owner 2002 Grand AM. 93K on the clock, running Mobil 1 5W30 since it's first oil change at 2K when it developed a leaky rear seal. Or it's second change at 5K. We're not sure if the dealer actually poured in the M1, we heard afterwards from an employee that the grease monkeys at that dealership would keep premium oils for themselves, and pour in the bulk conventional oil. Never went back to that dealer.
Every change from 5K on was done by myself at whatever interval the oil life system said to change at with M1 and whatever filter we could get... mostly frams (yeah yeah, I know better now) So 4K-9K depending on the season. It was mostly driven easy highway 100 mile round trip commute. It seemed to do lower miles in winter, and late summer... but I digress....
At around 60K miles, it started to get lifter noise. tick tick tick..... until it would warm up. Different dealer said it was piston slap, but I didn’t believe it. Since I had no intention of fixing it, I decided to ignore it either way, as this car is paid for, and is a keeper, and nothing’s getting fixed until it breaks. Tick got worse as time went on.
The oil fill is large enough that I can see several rockers under the valve cover, and I always look in there when I fill with oil. At around 80K miles or so, I started to notice deposits on the roller rockers. Looks like rust, but could be varnish. It sort of rubs off if I reach in with my finger. How do I tell if it's light surface rust or varnish? It's on the roller rockers, and seems to be spotty on anything steel, but not on the aluminum heads. Nor the steel springs. Seemed to get worse up to 89K. At 89K, changed over to AMSOIL 5W30 Series 3000 Heavy Duty Diesel oil. 3K miles later, the deposits don’t appear any different, but that’s probably not long enough to notice a change. However, the tick has vanished at some point during the last 3K miles. I’m guessing that there may have been a gunked up lifter and the diesel oil cleaned it up.
So how do I tell if it’s rust or varnish?
