The cons are once the hype is over folks will chase after the next marketing campaign, just like AI, just like block chain before that.
We still sticking with the predictions?
What is the hths?
5W30 VRP has a HTHS of 3.2 which isn’t bad.It's lower HTHS than I would like.
A real answer - thanks …It's lower HTHS than I would like.
Well that would be entirely dependent on the amount and type of VM used in the product. Have we seen reliable tests on here that show actual mechanical shear of the VII? Perhaps there are, I just don't recall seeing it.It's a RC API SQ oil so it's not going to be as shear stable as a Euro ACEA A3 oil. It behaves similar to Mobil 1. Fuel tends to cause it to dip into 30 grade territory. Amsoil SS back in the day used to have a HT/HS of 3.5 but they lowered it over time to help with FE. Now their 30 grade SS line only has a HT/HS of 3.0-3.1.
Good point. You're right it's not often from mechanical shear. I would guess that it's the type and amount of VM that causes the viscosity to dip. I really think it's more fuel related most of the time vs mechanical shear.Well that would be entirely dependent on the amount and type of VM used in the product. Have we seen reliable tests on here that show actual mechanical shear of the VII? Perhaps there are, I just don't recall seeing it.
For years I thought when I saw engine internals looking clean all was fine. Clearly not the case as you've stated. The rings are what take a beating and get deposit buildup over time.I found it interesting that Eric on YouTube "I do cars" recently tore down an Audi DI 3.0 turbo. The inside of the engine looked pristine, except for the oil control rings. These cars are typically run on ACEA C2 - VW 504/507 approved oils which is why it probably looked so clean inside overall. It's the carbon build-up in the ring land that seems to be the problem which is where VRP does its magic. The challenge for Euro car owners is VRP is not a Euro approved oil at this time.
Where have you seen that it isn't shear stable?No but it doesn't seem very shear stable, and combined with fuel dilution I see it dropping well below 3.0 in use. If it was shear stable I would be content with 3.2 cP
FE = federal emissions?It's a RC API SQ oil so it's not going to be as shear stable as a Euro ACEA A3 oil. It behaves similar to Mobil 1. Fuel tends to cause it to dip into 30 grade territory. Amsoil SS back in the day used to have a HT/HS of 3.5 but they lowered it over time to help with FE. Now their 30 grade SS line only has a HT/HS of 3.0-3.1.
Fuel Economy.FE = federal emissions?
Detected by whom? Blackstone?Every UOA shows this, viscosity drops more than it would/should from the detected fuel contamination.
Well that could be self propelled catch 22. How did the rings get dirty? How did the motor oil shear?Every UOA shows this, viscosity drops more than it would/should from the detected fuel contamination.
Good point - but in my case having a DI engine I will be changing the VRP oil at 3,500 to 4,000 miles max . It probably isn’t a good idea to run VRP much longer without an OCI .No but it doesn't seem very shear stable, and combined with fuel dilution I see it dropping well below 3.0 in use. If it was shear stable I would be content with 3.2 cP
