Valvoline Restore and Protect ATF 6qt box Amazon
Minneapolis
Seems like they're trying to promo it since it just came out a month ago. Looks like it's from the Valvoline store and sold by Amazon.
I dont know if $6.70/qt is a good deal but it was $54 and a better than the current gallon price ($35). It's definitely a great option if you're swapping exactly 6 quarts.
There is a hive mind post in the ATF forum on it that has a lot of good info if you're considering it for your application.
Valvoline Restore and Protect Full Synthetic Automatic Transmission Fluid ATF 1 Quart, Case of 6
Wow Solid price for 6 qts. And it looks like it is likely low viscosity and compatible with dex VI and Toyota WS, both of which I use. might have to give it a whirl.
I think this can be used in the applications you guys are speaking of:
Whether it’s a Ford, GM, Toyota, Honda, Hyundai, Subaru, BMW, Mercedes, VW and more, you get exceptional performance in any driving condition. For unsurpassed deposit removal and smoother shifting, trust Valvoline Restore and Protect Full Synthetic Automatic Transmission Fluid, from the #1 ATF brand.
  • Recommended for use in applications requiring DEXRON VI, DEXRON III, DEXRON II, MERCON LV, and JASO M315-2013 1A-LV
And on the latter spec:
JASO M315-2013 1A-LV is a 2013 Japanese Automobile Standards Organization specification for low-viscosity (LV) automatic transmission fluids. It ensures high performance, anti-shudder durability, and improved fuel efficiency, specifically for modern Asian and Korean automatic transmissions. It is commonly used as a synthetic, multi-vehicle fluid for DEXRON-VI and MERCON LV applications.
Key Details regarding JASO M315 2013 1A-LV:
  • Function: It is designed to meet strict anti-shudder performance standards required by Japanese automakers.
  • Viscosity: The "LV" indicates Low Viscosity, intended for improved fuel efficiency.
  • Compatibility:
    It is often recommended for many Toyota (WS), Honda (DW-1), Nissan (Matic S/W), Hyundai/Kia (SP-IV), and Mazda (FZ/FZ/MV) automatic transmissions.
Uhmmm wth? My local Walmart that I never go to. Came for Pennzoil Ultra Platinum bottles for rebate and found these 3 in the clearance aisle. Gallon Valvoline Restore and Protect ATF jugs for $20. Canceling my Amazon 6 quart boxes!
Maybe some confused soul poured it in a motor and the king of torts is at Valvoline’s front door 🚪
