[URed Line]http://www.valvoline.com/pdf/maxlife_full_synthetic.pdf[/URed Line]
A 10w30 may become obsolete soon in the U.S. but as a synthetic it will have the best oxidative & thermal stability of all the 30wts and will hold up best at high temps. It has the least polymeric thickener, so it runs very clean. It's also the most shear stable grade in turbocharged engines due to the low polymer.
In a SAE paper, Mobil found their 0w oils produced slightly more varnish and were slightly more volatile than their 5w/10w counterparts. Not significant enough to make it worth avoiding those grades, but there was a difference. You see this in most 0w grades among all brands. Narrow span oils produce less deposits also.
NOACK of Red Line 0w30 is only 424F and NOACK is 9%. That's 50% higher than the 10w30 which is 6% NOACK.
Platinum 0w-20, NOACK is 8.9%
Pennzoil Ultra 5w-20, NOACK is 5.0%
Quote:
So the volatility of the 0w-20 is 80% higher. This means it will thicken that much faster at low temperatures. The reason is that the most volatile components burn off first. These portions of the base stock and/or additive package provide the oil with its cold pumping characteristics. If you were to test both these oils after 3000-5000 miles of use, you'd see almost NO difference in cold weather performance.
15w-40 continues to be favored for commercial Diesel engines for this reason.
