Valvoline Extended Protection 5w30 at AutoZone
Atlanta, GA
Unsure of runtime as it is not stated, but current pricing is $4.00 per 1qt bottle.
I'd buy, but good chance the shelf will be empty after driving to the store. Most stores in my area show inventory of just a few quarts. It's not that good of a deal to warrant gambling.
So it is safe to presume Valvoline is phasing out Extended Protection due marketing overlap with Valvoline Restore and Protect?
I assume so.. All Valvoline Extended Protection had to be pulled from the back. Nothing on the shelf.
The manager actually had no idea that this was even oil - He said, " Don't you mean Mobil 1 Extended Performance?? 😂
Just scored 10 qts from an autozone a town away. They had 4 more quarts left but going to pass on those.
I've mentioned this in other threads but will share here too as this is an AZ deal.
There are lots of AZ motor oil clearance. Filter by motor oil and then by Deals > Clearance. You will find a lot of $4 quarts, some even $2 or $3. And a lot of $20 jugs.
