Valves noise would not respond to load on the engine.
Spark knock is probably what you hear. Try a good in tank cleaner [Techrom type].
Maybe go up a grade in fuel from 87 to 89, if you have to.
An occasional knock is OK.
Make sure the car is no running hot - stuck thermostat, bad fan, water pump, etc..
