Am using a 5W40 from a boutique blender the TDS shows a cSt at 100 c of 14.4
I've had two used sample reports come back from oil brought 12 months apart with V100 showing
12.5 after 6500km and 12.86 after 3600km on the second sample with the lab stating viscosity lower than the specification for the reported oil, incorrect oil grade reported.
Fuel dilution is under 2% and all other numbers are looking good.
Spoke to the companys lube tech line and they lodged a query with the formulation department but they seemed unconcerned with the lower readings in comparison to the TDS.
aside from the TDS data sheet on viscosity being incorrect ( I did raise that over the phone) why else would the oil drop viscosity so quickly without contamination
