Using saved Brake Fluid
I save remaining brake fluid for times when I need to flush a LOT of fluid and use the old stuff first. Example: after replacing a set of brakes lines. Otherwise, during a regular flush I only dump in new fluid.
Old brake fluid I dump with motor oil, transmission fluid, gear oil, etc...
Originally Posted By: Hootbro
Bought one of these years ago and has paid for itself in testing both the fluid in the vehicle and any stored previously opened bottles I have had to reuse.
What has been your experience of testing stored fluid. Does it stay good for several years
Longest I have tested a previously open bottle was two years on some store branded SuperTech (Wal-Mart) that initially tested at 0% water content new and was up to 1% water when rechecked. I still used it.
FWIW, I have also checked some new sealed Prestone branded DOT 3 that was 2% when first opened.
Useful information - thanks. The Prestone at 2% when new wouldn't last long. I thought you were supposed to replace fluid when it reaches 3 %
