So we're considering an Audi Q5 with the 3rd generation EA888 and direct injection.
Owners manual calls for 87 min but 91 recommended. Before you start, yes I am a cheap bastard that abuses every vehicle I own to the very last inch of it's life, within the parameters of not causing permanent damage. It is a ~$25 extra cost per tank to use premium.
I am not an automotive engineer but I will challenge that here in Canada where we get frigid winters for 8 months of the year, where the temperature dips below freezing and in the months of November to February where it can get to -30C or -22F, the engine is probably receiving an equally ice cold jet of fuel while the parameters are perfect for a turbo engine to NOT knock or detonate. IE we are so far to the edge of the temperature/timing advance tables that it just won't matter. Sometimes it takes 20 minutes of driving before the thermostat even opens in the winter. What do you think?
