Using Lectric Shave
  • Thread starter Thread starter Al
  • Start date Start date
Al
Elizabethtown, Pa
I started using it again. The almost empty bottle on the counter top has not been touched for decades. Used it and then went and bought a new bottle. Anyone else use it?
Second point. I have been using a norelco style 3 head shaver since forever. In January I bought a Series 3 Braun (Yea I should have bought a more expensive/better one (5 or 8).). Anyway, I found that with once a day shaving you needed to go over it forever. So now shaving in the evening also really cuts down the times. And I figure the lubricating of the Lectric shave will decrease wear and keep it shaving "better"
Yeah makes a huge difference especially if using a disposable razor. Speaking of I need to get my electric razor re-batteried. Can batteries plus do this?
I used lectric shave every day! I have cue ball dew so it makes it easier to run my razor over my face and head. I use the razor below in the link. It has served me well for the last 3 years since I stopped the dollar shave club. My blood count is up significantly and my wife's panic attacks from the horror of blood are way down... ;)o_O
I do need to shave every day for work. The shave is not as close and a multi blade razor.
razor
Blade, brush and soap in a mug. Only way to shave!
Well probably if a comparison would be done if you are using a single blade and cup you would find improvements with the Barbasol Thick and Rich and a multiblade razor. Further improvements with a 5 blade and a gel.
I stick with the Bic 3 blade and the Barbasol. My whiskers are so tough I barely get 2 shaves out of a single blade razor. Maybe 4 with a 3 blade. Thats why I use an electric.
