I have a sweeping oil pressure guage on the dash ('96 Bonneville with 3800 Series 2, a swap-out such that the engine has under 25,000 km while the odo reads 115....anyway for all I know you have the same sort of guage on YOUR dash)
...anyway, when I start it in this weather it takes 3, 4, 5, 6, maybe 7 seconds for the oil pressure needle to get out of the red zone. After 5 secs there is a dinging sort of advisory chime though no lights on the dash or anything. (The advisory chime is, IMHO a real design flaw. If I have 5 psi after 6 secs of engine running I want to know it; it's a larger issue than driving with a turn signal left on, know what I mean?
BTW I have a block heater and paid $30 to ensure it was in tip-top shape a few months ago, and I use it.
But I'm thinking; I had left the Redline 5W30 in my garage because its pour point and cold pump-ability weren't as good as the GC 0W30. So I'm running GC. I like Moly and GC has none, so there is Schaeffer's Moly in it, which was some good coinage to get into Canada. There is also (full bottle) Auto-RX, which good sources have assured me will NOT affect cold-weather pumpability, since there was a good 1000 km for it to blend the A-RX with the GC before this unseasonal cold snap hit us. And, as luck would have it I got a filter change 1000 km after putting in this custom (expensive) mix, free. UOA from the previous owner (the dealer) support their claim that it was a newer engine (SI was over 40) with just test-drive mileage (under 200 km) on the previous oil change (before I knew that the car was for sale)
Is there anything more I could have done? I of course want the time that that needle is in the red zone to be as short as possible. I would think the time in that red zone is directly proportional to wear metals on next UOA; is that a wrong or over-zealous assumption on my part? What could be done to reduce the time in the red zone? Drain and replace with straight GC? Quickly switch to Redline?
THANKS!
Rob
THANKS!
Rob
