Using fuel use to determine oil change interval
CA
I've seen it mentioned many times that using fuel consumed to determine when to change oil is a possible method along with hours and miles.
So what exactly is the formula here?
I presume we need:
Gallons of fuel consumed
Sump size
Engine size
Once we have that info, what calculation do we perform?
I've been here WAY too long and remember too much of it...
https://bobistheoilguy.com/forums/ubbthreads.php/topics/35025/Re:_Kublin_Method--the_ultimat#Post35025
Originally Posted By: TooSlick
Rexman,
The oil change formula posted over on the 3MP is NOT the correct one. This is the actual formula I developed:
OCI = (C*)(ave mpg)(sump in qts)(cubic inches/Hp)
Where C* is a constant which was derived by looking at oil analysis data I've accumulated over the last 10 years. For Amsoil I use a C* of 120, which generates drain intervals of approx 7500 miles for a turbo or motorcycle, up to 15k-20k for a low power density engine driven easily on the highway. If you have an application where you are dirt or soot limited, you can't use this formula and get a good estimation of oil life.
You CANNOT use the TBN times ten as a substitute for this C* value. The rate of TBN depletion varies significantly depending on the quality of basestock and additive chemistry. In addition, TBN depletion is non-linear, as you have seen from the 3MP tests. In other words, a 6 TBN oil will not last 50% as long as a 12 TBN synthetic. In actual practice, it might only last 25%-33% as long.
I don't have as much data on other oils as I do with Amsoil in deriving additional C* values. For Mobil 1 I suggested using a C* of 80, based on the limited data I've seen on this site. For an average quality petroleum lube, I think a C* of 40 is reasonable. The implication of using these various C* values is easy to see ....
Please feel free to contact me off-line if you have any other questions about this OCI formula. BTW, I've made my living as a propulsion engineer for the past twenty years - the Amsoil stuff is something I do on the side.
Tooslick.
Dixie Synthetics
Ted was an Amsoil dealer fyi.
Work out your own formula. Example?
My 2003 4Runner V8 Avg MPG=19 (current average over all kinds of driving that I normally do)
10,000-mile OCI Current OCI
10,000 miles/19 avg mpg = 526(rounded off) gallons of gasoline. Insert some fudge factor.
Change oil every 500 gallons of gasoline.
Current used oil analysis with 10,000 OCI
My situation is very constant so I just do my OCI by mileage otherwise I'd work up a gasoline use formula. If I lived where there was a big change in the weather from summer to winter I'd probably use such a formula.
If you did idle the engine more or work it harder towing or off-roading you'll use up 500 gallons sooner mileage wise so you'll automatically be adjusting the OCI.
If this makes any sense to you then you can figure out your own formula and check it with a used oil analysis.
A friend that has a dozen or so service trucks that service microwave towers, some or most of them in very difficult areas to reach so he uses such a formula. He's been doing it this way for over 25 years and his results are excellent. He started with a nominal interval of 5000 miles to create a formula for each truck and now some trucks get an oil change and other services at less than 3000 miles depending on conditions. A couple of his trucks have power-takeoffs that run all day long and this system compensates for that. used oil analysis prove that this system works for him.
Gives 11,000 miles for my Colorado using the M1 number.
Holden say 15,000km 9,300 miles. However with my driving style, the OLM looks like it's heading for 11,000 miles plus a bit.
Rexman,
Tooslick.
Dixie Synthetics
Thanks for that.
It's certainly interesting and the "C" is everything really.
Funny how he essentially says you can run synthetic twice as long as conventional and amsoil three times as long as conventional.
On the older BMWs, say 1999-2006 when you would reset the interval it would blink 3250L, which means 3250 liters of fuel. That works out to about 860 gallons of gas, and using my 15 mpg avg on my x3, (shorter trips, wife driving, loves to warm it up for a while, wasteful) would have an interval of about 12,800 miles, with the yellow or flashing warning starting at about 10k. The higher performance M cars resets to the same fuel interval, but their likely worse fuel economy will bring that interval down to around 10k. Some people with more highway miles and averaging 18 miles per gallon would be able to go almost 15,500, which is the limit per BMW.
Makes you wonder what info is used to create the algorithms that are used for "Oil Life Monitor" calculations
Probably something pretty similar.
In June of 2000 BMW changed the E46 3 series Service Interval (oil life) Information monitor to be based on gallons of gas used.
7 quart sump, 2.3,2.5.2.8 or 3 liter engines.
Using a 328i as an example:
Standard transmission model: SII
illuminates after consumption of
601 gallons of fuel.
Automatic transmission model: SII
667 gallons.
The miles to service displayed was based on a 25 mpg average when the originally reset, typically ~15,500 miles.
Different driving conditions (mpg) would give different intervals.
They may have varied the gallons based on the displacement, I don't know for sure.
I was looking at some auction vehicles in appleton wi , they say they use 600 gallons of fuel to dictate the oil change on police and public service vehicles as squads do a lot of idling
Nope, it is far more advanced including the work put in to arrive at it.
Check bbobynski's posts back in 2005. I found them yesterday and they're amongst the best stuff I've read here.
https://bobistheoilguy.com/forums/ubbthreads.php/ubb/userposts/id/6718
It's interesting that the formula takes you to a similar point as the OLM if you assume M1.
But isn't the OLM in Australia calibrated for conventional oil, in which case the formula might have you as low as 5,500 miles?
My own retrospective calculation for a (full syn) oci where I have a used oil analysis and have to guesstimate the mpg, gives me something that seems in the right ballpark too.
I do think that assuming C=40 for conventional is too low as that seems to make manufacturer recommended ocis too long.
C3/Dexos 2 5W30 is specified by the manuals...So yes, any dino that meets those three specs would give the same result on the oil life monitor.
Of course I could throw in SAE30 small engine oil and it would tell me exactly the same answer, as it's assuming that I've used the specified oil in the first place, isn't it ?
The wagon trains that deliver Colorados to Australia are capable of carrying oil too...even synthetics.
The point I'm making is the fuel consumption formula in your case is way off if C is set to 40 for conventional.
OF COURSE IT IS OFF IF YOU SET C FOR 40 (conventional).
Your statement was...
I don't know, I didn't calibrate it...did you ?
GM specify ACEA C3, or DEXOS2, an in grade 5W30...
Holden (GM) seem to be implying a synthetic here, aren't they ???
OK, in before the clarification...where did you get that GM calibrated the OLS for the C3 DEXOS2 5W30 conventional...can you give me a data sheet to one of them ?
I phrased it that way because I had read that the OLM in the US was calibrated for conventional oil. No idea if they had done something different over there.
The fact that you plugged in M1 / C=80 made me think that maybe there was a different requirement over there.
Edited to add: user bbobynski back in 2005 shared a lot of information on the OLM and how it was calibrated for the most basic approved oil.
Isn't the Colorado in 2017 calibrated to DEXOS (2 in my case)...I'm VERY sure that didn't exist in 2005...
Right. It is calibrated to the oil requirements of every vehicle.
I didn't know at the time that your vehicle was specified for dexos2. But I wasn't claiming it was calibrated to something in 2005! Simply said oil requirements.
So is dexos2 available in conventional? Am not very familiar with it.
Not sure I really care to know now. Seems like you got out of the wrong side of bed or something. Thanks for pointing me to the formula the other day.
