Shortly after my last fillup, Shell 93, I have noticed a miss or stumble that will sometimes occur while steadlily driving at 50 MPH or so. Or basically while I am not placing and kind of load on the engine, and I do not see this while accelerating or wide open throttle. I am very particlaur at doing maintenace, and the usual maintenace items have been replaced less than a year ago. Since I have heard of other people getting bad tanks of gas, that has led me to look here first before pulling the plugs. Usually I try to keep the tank above half, but I have let it get down to a little less than 1/4 tank the past few times. I don't know if this has contributed to moisture somehow condensating in my tank during the colder weather.
I have never really been a fan of using any kind of additives, but I am contemplating using some drygas in this situation. I have heard before with fuel additives that it is best to do an oil change after the next fill up. I don't know if this is true or not, but if this is the case, does the same apply with drygas?
If it is contibuted to a bad tank of gas, should a couple of refills cure this assuming that they are not contaminated?
