Originally Posted By: mrdctaylor
Guys,
My wife and I just got back from a nice trip out west. It look us through parts of Utah and Colorado. When coming down long declines out of a mountain pass, I usually manually kept my automatic transmission in 2 or 3 depending on how fast I was comfortable going. It was never at high or even moderate RPMs. I'd always heard this was safer because if you ride your brakes down a mountain they can overheat and fail.
Anyway, I've had some people tell me that it will wear out my transmission. Obviously, I want to be safe but I'd also rather wear our brakes than a transmission. For those of you that live in mountainous terrain: what is the proper procedure? Should I manually downshift my auto to keep the speed low on a long descent or should I just leave it in D and use the brakes?
Thanks in advance!
PS. This was in my 2012 Highlander. It has a "manual" shift mode where I can control the gear my tapping the gearshift towards the "+" or the "-".
Ski twice a week from mid October to June. Sometimes I put between 18-20,000 miles on BMW in winter just skiing here in CO. I use manual shifting not just to go down but cutting corners. Going down in X5 diesel and manually slowing it down is very efficient bcs of high compression. So far never had issues, and gearbox works as usual.
I was actually considering that 2nd gen. Highlander at one point, and did not like it particularly bcs of slow response when one does manual shifting, because I use it a lot.
So, nothing to worry. Gears are there for a reason.
