using Amsoil 5W-40 in a new motor???
North Dakota
I've been lurking here a for a while and I've done quite a bit of research on oil, but I just don't know if using the 5W-40 is the right choice for my car. I drive a 2005 dodge SRT-4, it's not a daily driver and I drive it like I stole it.
I just hit 1300 miles on my new ride and I changed the break in oil out and put Amsoil Euro 5W-40 in. The motor is a 2.4L turbo (the turbo is water and oil cooled) and owners manual suggests using 5w30 mobil 1 but through other channels I've learned the designers of the car actually recommend Mobil 1 0W-40.
I just don't feel comfortable using a thin 5w30 in a turbo car that is driven aggressively on a regular basis, but at the same time is the Amsoil 5W-40 overkill and is it detrimental to a brand new motor?
Although it's a turbo engine the temps rarely rise over 210 F(99 C) and this is only at idle, but since my temps are not extremely high is it neccessary to have a thicker oil?
I've used Mobil 1 0W-40 before, but the Amsoil 5W-40 seems a lot "thicker" and I'm kind of concerned that I'm losing a little flowability in the valvetrain because of this.
I'm just looking for some opinions on my choice and if someone has a better suggestion for the right oil for my motor. Thanks
Well, you'll get plenty of opinions ...heck, I'm waiting for someone to say that you need 5w-20 ..and should thin it out with some agent.
The only liability that I can see with a 5w-40 over a 5w30 is short trip fuel economy. I've never used the Amsoil 5w-40, so I will leave that part to others. The weight is just fine, IMHO. Others may not agree. Can I assume that this won't be doing too many "Frostbite Falls" -30 starts?? If so, then perhaps winter would call for an alternative oil.
quote:
Originally posted by Steve S:
what do you mean by flowability in the valve train?
I've been told that thicker oils don't flow as easy and lube the valvetrain components properly/enough, but I'm not sure that I subscribe to that school of thought.
The car will not see temps below 30 F it's a summer car, and I don't care about gas mileage so much, I just want good protection for my motor for my driving style.
I've seen others with the same car using Amsoil S2K 0w30 and swearing by it, I just don't know what to do, I love my car and want it to last forever lol.
Do they offer the SRT in some other country? Check the spec'd oil anywhere else but North America. You'll probably see a 40 weight spec'd. I wouldn't worry at all about it.
The Amsoil Euro 5W-40 is an excellent oil, has a HTHS of 4.2 and is designed to go the longer OCI that is now recommended by alot of
Euro cars. Currently I use it in my wife's '01 1.8T VW Bug.
The cars seems to run better with this oil with no start up probs at below 0 starts here in Michigan.
I use the Amsoil 0W30 in my new "04 Acura TL with similar positive results.
Craig
I'm surprized that none of our Amsoil reps have commented.
The oil will do fine, but I do question the uncomfortableness with a XW-30 in a turbo motor. If the car is spec'd for a 30 then it will do fine.....but what are the other channels that say to use a 0W-40?
The 5W-40 will pump up fast enough to protect your valve train, so that shouldn't be a worry either. Just stick with the recommended OCI and make sure you do a used oil analysis for us to see!
Amsoil has good products, but I'm not sure the 5W-40 Euro is best for you. I think you will still get excellent wear protection, better gas mileage, and snappier throttle response with one of their "thinner" 30 wts.
No worries, but you might want to consider a lighter shear stable synthetic.
