Originally Posted By: Oregoonian
Originally Posted By: born2push
Its got 92000 miles. Im just a perfectionist and wanted some opinions because the Mobil 1 oil filter is about 14 dollars. Also Toyota recently changed oil change intervals to 10000 miles if using synthetic.
Mobil 1 Advanced Fuel Economy 0w20 will easily do 10K OR switch to Mobil 1 Extended Performance 0w20, which is guaranteed for up to 15K (same price at WalMart). BTW, a 1/2 quart usage per 5K is nothing to worry about.
To save a few bucks, you might consider switching to a Fram ULTRA filter (under $9 at WM). Its a top-tier, long OCI filter, that has synthetic wire-backed media and can go up to 15K. Here on BITOG, the ULTRA is considered by many (including myself), as one-of the best available.
Agreed with everything mentioned above.
If you use either Mobil 1 Advanced Fuel Economy or EP 0w20 and do 10k OCI, then add 1/2 quarts at 5k and change oil at 10k without any top off.
