How important is it to keep the aftermarket filter specs close to the one that came from the factory on the vehicle ?
For instance the bypass valve relief pressure ? The truck in question is a 2016 F 150 5.0.
Motorcraft FL 500 is set at 8 psi , the Wix 57502 is set at 22 psi. Does this affect start up below freezing ?
Sorry for my ignorance when it comes to filters. But it is kinda hard for me to find info using this forum's search.
Thank you for your time.
