I have a 1998 Toyota Camry V6. I have a very small oil leak and it seems to be coming from between the block and transmission. From a hole that looks like you use to pry them apart. Well its hard to really pinpoint. SO looking on-line, I found a couple of stop oil leak products you add to your oil. One from Lucas which is $100 almost and another few on the market. Is it worth it to risk paying that much for the product? Is it even a risk? Personal Exp? Really cant afford costly repair. Thanks alot for response.
