I used original green Zerex in my mother-in-law's '03 Altima 3.5L. After a great deal of research here and other places I am still slightly confused. It seems there should be no real issues this coolant would cause in this car, but it seems most people say the OEM or G-05 would be a better choice. I also use reverse osmosis water when doing my cooling system services. My question is really regarding the original Zerex. It must have a better anti-corrosion package than the old traditional ethylene glycol coolants as it is rated for 5 year/100,000 miles. It also actually has less silicate than G-05 and the Japanese makers call for silicate free. Check out the data sheets:
http://www.valvoline.com/products/zerexoriginal.pdf
http://www.valvoline.com/products/zerexg05.pdf
So does anyone see any real issues with using this coolant in Nissan's?
I've used it in my wife's '99 Altima 2.4L for several years now with about 30,000 mile changes without any issue. Everything (including 90's model Fords) I've used this green Zerex modern formulation in has held up well with sparkling clean cooling system metals and no water pump failures. (I probably just jinxed myself, but oh well) I'm certainly not sold on the "one fits all" mentality of Prestone and the like.
