Used Oil Sample, did I waste my $ ?
Waldorf, Maryland
Switched from Mobil 1 to Castrol Edge in my 1998 Corvette (seeing if I will get reduced lead readings), just changed oil (drained the Edge). I didn't take an oil sample when I should (halfway into drain). I was checking oil level in transmission and adding some oil when I remembered to sample oil, all oil was drained. I then raised rear and drained out last 4 ounces. This last 4 ounces could contain more metal, we will see. If I show a lot of lead, it may not be conclusive due to sampling.
Opinions? Did I waste my money submitting this oil sample?
