My g/f drives a 97 Saturn s2 that burns abou a quart of oil every 1k miles. We top off the oil frequently to keep it from being under filled. The vehicle has 148k on the odometer and we intend to keep this car until it dies. Recently it went through two auto-rx clean cycles which did nothing for the oil consumption issue. We than decided to use 10w-40 oil to keep consumption down. With cold winters approaching, we bought 24 qts. of Pennzoil 5w30 conventional Saturn recommended weight that was on sale recently.
So here is the dilemma. I've acquired several Mobil 1 Extended Performance M-102 oil filters that are intended to be used for 15k. This vehicle will get 3k oil changes. Will it be alright to keep the filter on for 3 consecutive oil changes since it will only equal roughly 9k on the filter itself? Fresh oil will be put in every 3k with the dismount of the oil filter. I will than pour out the old oil out of the filter, fill with new oil, and re-install.
I know that some argue that filters need to be replaced every oil change. Is this still the case with the Mobil 1 filter as it's made for 15k oci on the same oil? The Saturn will get new oil every 3k and the filter will only have 9k of service on it, no where reaching the end of its service life that is intended for 15k.
