Here's a bigger filter that xref's from a Donaldson that is the same gasket size ..but the Wix is slightly bigger. In practice, it appears that this minor difference in gasket size doesn't prove to be a limiting factor. The main limiting factor is anxiety
Here's the Wix
Part Number: 51347
UPC Number: 765809513471
Principal Application: Ford Courier (72-82), Hyster, Komatsu, Merc. Bobcat (75-79), Pinto (75-79), Thermo-King, Yanmar Excavators
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height:
4.828
Outer Diameter Top: 2.921
Outer Diameter Bottom: Closed
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Burst Pressure-PSI: 325
Max Flow Rate: 9-11 GPM
Nominal Micro Rating: 20
Gasket Diameters
Number O.D. I.D. Thk.
15597 2.734 2.430 0.226
Here's the Donaldson
P555522
Lube Filters Product Attributes
A - OD (Inches): 3.12
B - Thread Size (Inches): M20 X 1.5
C - Length (Inches): 3.87
D - Gasket OD (Inches): 2.45
E - Gasket ID (Inches): 2.15
Relief Valve Setting (PSI): 11-17
Anti Drain Valve (Y/N): Yes
Product Type Description: LUBE SPIN-ON FULL FLOW
Primary Application: THERMOKING 11.5522, J.DEERE,
Primary Application 2: YANMAR
If you desire to search for more, go
here. and put
M20 X 1.5 (tape and paste just like that) in the search window (up and to the right) and you'll get hundreds of filters ..must of them with much bigger gaskets. This appears to be the thread of choice for asian based engines of all sizes.
