I still hold that all things being equal, factory-installed batteries are better for longevity. The factory batteries (all made in Japan) in my cars have lasted a ridiculously long time, although at least I replaced just because I felt like it. They also had caps where I could add water. Factory installed batteries have some unique considerations, including cars that may sit on the lot for months without being started or charged. I've seen some dealers use charging carts, but that's more the exception than the rule.
I've seen plenty of batteries that were marketed as "north" vs "south" versions at the same price, same weight, reserve capacity, etc. I'd rather have the version meant for warmer climates. The only difference would have been the thickness and number of the plates. For my climate I would prefer thicker but fewer plates because I don't run into issues with cold starting. Even if I'm taking my car up to the Sierra Nevada, it still doesn't get cold enough to matter. This article is from Australia where they generally don't deal with freezing winters.
As for LEDs for the map lights - I've already done that. I was only talking about what happened years ago.
You are trying to project your imagination of what seems ideal to you, as a replacement for what is reality.
No. That is all nonsense. Focus on science and go from there.
Yes, northern batteries have more porous plates and that's about where the difference ends.
You describe a preference for a hybrid staring/deep cycle or just a deep cycle. This is not some word game or nonsense implied, these are standard battery types and if you want that type, it is simple enough to choose that. It has NOTHING to do with nonsense implied about OEM batteries. OEMs use a starter type battery because it meets the warranty period for colder climates too, and that battery has no mythical or magic properties.
There is no nonsense about special plates. That is entirely determined by the type of battery, what application it's targeted for
