UOA's 2006 Dodge Sprinter, NAG1 Transmission
Northeast Ohio, United States
This an analysis of a sample of the ATF in our '06 Sprinter taken as I was changing it for the second time. The vehicle currently has around 154K on it, and 30K on the ATF. I will pull a sample at 180K and see how it looks.
Early ?
I did the rear end as recommended, at the 4th maintenance service (120K miles)
Rather than just draining thru the plug, I pulled the pumpkin so I could have a look at the gears and the interior .... the gear oil was clean and there no sludge or metal in the bottom of the housing - in fact, I sopped up the remaining gear oil in the bottom of the axle housing with paper towels .... and there was no discoloration on the towels - other than what clean, amber (transparent) gear oil would make. (I was amazed)
Of course, it was built in der Vaterland ....
Yes, I did.
The original recommendation from MB - back in '03 I think, when they introduced the vehicle here in the US - was only once @ 80K miles
.... apparently a little too optimistic
.... at some point (by the time I had gotten the vehicle in '06) it was revised to once every 60K miles.
