Car: 2007 Mazdaspeed 3 77500 miles
Oil: Mobil 1 5w30
Backround: I have had a used oil analysis performed at every OCI beginning at 9800 miles The Fe number at that mileage was 40 ppm(5000 mile OCI). From that point on the Fe number decreased to 25-28 ppm while the OCI remained @5000 miles- dropping to 19 ppm at my prior oil change(5200 mile OCI). The 5w30 has always remained in grade and the TBN has never dropped below 3.0. No fuel dilution above a trace and no issues with insolubles, silicon, water, or coolant. The initial Cu number was 83 ppm(!) but quickly dropped into the 1-3 ppm range. Pb has always ranged from 0-2 ppm.
Question: My last OCI was 7400 miles. Vehicle mileage was 76700 miles. If anything, I have been driving the car easier than I usually do. The used oil analysis revealed that everything was normal except for Fe, which jumped from 19 ppm to 38 ppm. I realize the OCI increase may be responsible for part of the increase, but not all, especially considering that Cu remained at 2 ppm and Pb at 1 ppm. So, is the Fe spike a legitimate cause for concern? Thanks!
Oil: Mobil 1 5w30
