Since its 3rd oil change, I've kept Pennzoil Ultra 5w-20 in my wife's 2010 Mazda 6i and changed every 7K-7.5K. At 40K, I recently took it to my local garage, and had the oil and filter changed, installed new front brake pads, and had the AT fluid drained and refilled (not flushed). The mechanic advised I had a small oil leak/seep around the timing cover and that I should get it checked out by Mazda b/c it might be covered under warranty.
A few days and 100 or so miles later, I took it to the dealer (after hours) to have a door latch recall service performed and asked them to check out the timing cover leak while it was there. We had to leave town unexpectantly for a few days, but the dealer said the leak was coming from the oil pan where it met the timing cover.
They dropped the pan, resealed it, and refilled with Castrol GTX 5W-20 (under warranty)before I had a chance to tell them about the recent oil change and request to keep my oil..
My question: Should I just keep the Castrol in there for a 5K oci and then go back to my normal oil and schedule?
