Unknown 5w30, 2000 miles, 2003 Chevy Venture 3.4L
Plattsburgh, NY
The results from an abnormal sample from my Dad's 2003 Chevy Venture, that I had long considered lost, came in today. (A little over two months, after sampling) The odd thing, apart from the time it took, was that I had sent the sample to the ALS Tribology lab in Atlanta (Amazon WIX kit), but the results came from their lab in Ohio.
The vehicle had a bad lower intake manifold gasket and coolant was getting into the oil, causing sludge. The LIM was replaced. Sorry for all the "Unknown" entries -- this is my Dad's vehicle and he's not as meticulous as I am about this stuff.
Original thread here:
BITOG: [cut-open] AC Delco PF-47E (Sludge in Center)
Better late, than never, I suppose.
Originally Posted By: ALS Tribology
Engine wear levels appear satisfactory for first sample. Silicon level (dirt/sealant material) satisfactory. Water content acceptable. Sodium and Potassium levels indicate internal coolant leak. Viscosity within specified operating range.
Action: Check for source of coolant leak and repair. Change oil and filter(s) if not already done. Resample after corrective action to further monitor.
Code:
Lab Used ALS - OH
Oil Brand Unknown
SAE Grade 5w30
Oil Specification Unknown
Oil Filter ACD PF-47E
Oil Additives None
Miles in Use 2,000
Time in Use (Months) Unknown
Miles on Unit 151,862
Sample Date 10/05/2012
Make Up Oil Added None
OLM Reading (% Left) Unknown
ELEMENTS (ppm)
ALUMINUM 3
CHROMIUM
IRON 6
COPPER 17
LEAD 12
TIN
MOLYBDENUM 29
NICKEL
MANGANESE -
SILVER
TITANIUM
POTASSIUM 132
BORON 38
SILICON 11
SODIUM 190
CALCIUM 1581
MAGNESIUM 8
PHOSPHORUS 659
ZINC 766
BARIUM
VANADIUM
Values
Should Be
SUS Visc @ 210°F 57.5 57-65
cSt Viscosity @ 100°C 9.6 9.30-12.49
Flashpoint in °F - >365
Fuel % -
Antifreeze % YES 0.0
Water %
Insolubles % -
Soot % -
TAN -
TBN 4.7 >1.0
Oxidation % -
Nitration % -
Sulfation % -
FOOTNOTES
[1] Short Notes: Bad LIM Gasket
[2] Short Notes:
[3] Short Notes:
No, my Dad didn't have the head gasket fixed, since his mechanic confirmed a LIM gasket failure on his van. The LIM gasket was definitely shot.
Originally Posted By: addyguy
I'd say it's GTX.
Typical 3.4 results at some point in it's life.....
Or Valvoline conventional. The additive packages are nearly identical. The moly and boron look residual from the last oci.
