Say What?Can universal coolants be added to Dexcool without changing the Dexcool's color?
In that case I guess I'll have to wait until the rebuild to change coolants.The only coolant I would add to Dexcool is Dexcool.
That sounds like a good plan.In that case I guess I'll have to wait until the rebuild to change coolants.
The correct answer is old school IAT green-that’s when the BAD stuff happens.The only coolant I would add to Dexcool isDexcool.
Probably not. Might only be a minor variation in color, depending.Can universal coolants be added to Dexcool without changing the Dexcool's color?
Dexcool came out in 1996 IIRC and it was a Texaco product that GM used. The intake gasket material in some cars didn't play well with Dexcool but the problem was solved with upgraded gasket materials. I would agree that Dexcool/Dexclones would probably work well in most modern vehicles if properly flushed of all other coolants before filling your system with a 50/50 mix of it.Probably not. Might only be a minor variation in color, depending.
The good news is DEXcool is not an expensive coolant.
I might assume that you want to use a non dexclone universal coolant but your under warranty so you don’t want it to be obvious?
DEXcool is a perfectly fine coolant. It’s been working well for many years now. 30 or 40 years ago there was an issue that is still wildly exaggerated and misunderstood and just not existent anymore.
This particular poster has a long history of posting questions just like this. Hard to tell if they are fishing expeditions or a legitimate questions.Is there a reason color matters to you other than aesthetics?
Car is not under warranty. My worst fear is mixing in a different coolant and the color changing to brown.I might assume that you want to use a non dexclone universal coolant but your under warranty so you don’t want it to be obvious?
The original Dexcool also seemed to have issues if air could get in the system. Through a faulty radiator cap in some cases. Unsure if the new AMAM still has issues if air gets into the system but not sureDexcool came out in 1996 IIRC and it was a Texaco product that GM used. The intake gasket material in some cars didn't play well with Dexcool but the problem was solved with upgraded gasket materials. I would agree that Dexcool/Dexclones would probably work well in most modern vehicles if properly flushed of all other coolants before filling your system with a 50/50 mix of it.
Did any car that came with Dexcool from the factory have a non-pressurized coolant overflow tank?If it has 2-EHA, it has the issue. This includes GM-licensed Dexcool as well as dexclones like Prestone.
The problem is more prevalent in non-pressurized coolant overflow tanks, where it's easier for air to enter the system, especially if the coolant is low.
That generation Jimmy / Blazer 4.3 and they had issues.Did any car that came with Dexcool from the factory have a non-pressurized coolant overflow tank?
