I will be undertaking the upper and lower intake manifold gasket replacement on my 3.1L 2002 Century next weekend, and I have a few questions for those of you in the know.
1. Is there any reason why you cannot just disconnect the fuel rails and their electrical connectors from the fuel lines and remove them still attached to the manifold? Along the same line do I need to buy/borrow any special tools to relieve the fuel pressure, and disconnect the fuel rails from the lines?
2. Another question I had is in regards to the ridges between the intake and the head, it looks like a gradual S. Do I need to use a bead of sealant there or do the gasket kits supply something, if not do you guys have a recommended sealant?
3. Is it necessary to buy the new bolts from GM, or can I use the old ones again if I apply some blue threadlock?
4. And last but not least, as long as I keep the pushrods in order, is there really anthing to worry about when reinstalling them?
Thanks for all your time and help with this, it is appreciated. Any other suggestions please post.
