You can clearly see the cams in one pic…These are really next to the valve cover photos, not under![]()
Horizontal layout..You can clearly see the cams in one pic…
Yep, that's my opinion. It was always considered a lower quality oil, certainly not of the same caliber as an XOM or Pennzoil offering. And if you read my post I also said the 10K OCIs after the Trop Arctic was not used didn't help. The pictures aren't lying either. Searching the site reveals engines with similar mileage looking better. Don't get me wrong it isn't horrible, but this is Bitog and the pictures were posted for discussion. Others commented about the sludge and varnish as well.Really you think Trop Arctic is to blame !
Where did you get the info on it not being quality oil !
Not refuting your post !Yep, that's my opinion. It was always considered a lower quality oil, certainly not of the same caliber as an XOM or Pennzoil offering. And if you read my post I also said the 10K OCIs after the Trop Arctic was not used didn't help. The pictures aren't lying either. Searching the site reveals engines with similar mileage looking better. Don't get me wrong it isn't horrible, but this is Bitog and the pictures were posted for discussion. Others commented about the sludge and varnish as well.
I should change it to “behind the cam covers”.Horizontal layout..![]()
Ok, either way there's an issue. Regarding Trop Arctic, I still think XOM and Pennzoil offerings are better. Super Tech is considered by many a very good oil, it is. But IMO there are better choices than that too. As far as the first 65K miles, that's unknown history which could very well be a contributing factor too, so we agree on that. That's something we will never know though. As always opinions vary.Not refuting your post !
i tend to think the prior 65k may be the issue.
Trop Arctic is a syn blend from a big enough company which tested out fairly well on pqia when he was using it really no worse than the big companies.
It was a joke. As in not many know what real sludging looks like. And I call it very clean, that is nothing abnormal at all.I don't believe so.
I'm curious why the oil couldn't handle how it was used.
I know that, I was joking back.It was a joke.
Here’s the other side. It was leaking as well. Spark plugs were NGK irridum with about 60k on them. Probably had quite a bit of life in them but changed them out with some NGK g-power while I was in there.
drivers side is harder than the passenger side. The bottom bolt is a nightmare. Spent 30 minutes getting it out 1/60th of a turn at a time and another 30 minutes getting it back in 1/60th of a turn at a time.
View attachment 136382View attachment 136383View attachment 136384View attachment 136385View attachment 136386View attachment 136387
